rogers roost
olds 455
« on: July 04, 2007, 03:38:56 PM »
hey I heard that having a olds 455 w/performer man. you don't need to use the lifter valley tin thing? really my question is can I just use a regular intake man. gasket? and if so what is the best one to use?I think I heard that from Mondello's mech but not sure... ???
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
a.k.a.YOUR NEW BEST FRIEND
crewchief22
Re: olds 455
« Reply #1 on: July 04, 2007, 03:51:21 PM »
As long as Edelbrock has not changed the design since I was selling them, you are correct.  The original Olds manifold did not seal off the intake valley like the Performer does.
  • Boat #1: '77 Hondo Pantera GT Jet
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
"Racing is life!  Anything that happens before or after, is just waiting"    Steve McQueen
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
rogers roost
Re: olds 455
« Reply #2 on: July 04, 2007, 05:17:58 PM »
so do you know what brand of gasket is the best?
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
crewchief22
Re: olds 455
« Reply #3 on: July 04, 2007, 08:06:54 PM »
We sold Mr.Gasket when it was still Mr.Gasket.  I think FelPro has a gasket available in their performance line.
The gaskets we sold were a thick paper type gasket, kind of like a header gasket.
Any good speed shop should have something or you can call Jeg's or Summit if you have to  ;D
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
GAWnCA
Re: olds 455
« Reply #4 on: August 03, 2007, 06:57:21 AM »
Hey Crewchief,  Why is it that everyone is so against the Olds 455, other than the fact it's hard to find parts for them?  What is the real weaknesses of this mill?  and are they good enough just for river cruising?  I'm not a hot-rodder anymore but a burst of go-fast now and then is fun.
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
~Greg
Forgive your enemies.  It messes up their heads.
hotrod56cars
Re: olds 455
« Reply #5 on: August 03, 2007, 08:00:32 AM »
I'm not Crewchief but I have read a LOT about the Olds 455. It's a great engine with a design flaw (for boats or racing), the oil doesn't return to the pan fast enough. The oil return passages in the cylinder heads need to be drilled out larger or hit with an air hammer and a larger oil pan than stock is also recomended. I've read over and over that you don't want to run it over 4,000 RPM for extended periods of time due to the oil return problem but it will handle W.O.T. runs for short periods.
My Miller had a 455 with a larger than stock oil pan and the heads had been drilled. I cruised that boat for hours straight at 4,000 RPM with no problems whatsoever and every so often over that 4,000 RPM mark. I had it to 5,800 RPM for a very short period of time (? 5 seconds ?) with no problem. It had great power for a stock mill.
Another friend of mine had a Olds 455, an acqaintence flocked with the water inlet valve and my friend blew the engine up. He switched to a 460 Ford and his boat was substantially slower than with the Olds.
I've also read build-ups on the Olds 455 and they can make a lot of HP.  ;)
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
Quote
NO REGRET$ ... Arguing on the internet is like competing in the Special Olympics / no matter how good you do you're still retarded!!!!!
                                                          1978  19' Mach 1 Tunnel jet
wanabe
Re: olds 455
« Reply #6 on: August 03, 2007, 01:47:16 PM »
I just went thru this and since it was my 1st, I did a lot of reading; I think everyone said DO NOT use valley pan; use Mr. Gasket or FelPro gasket; consensus was DO NOT use the rubber fillers for front/rear; use a bead of RTV instead (place intake on first and eye-ball how thick a bead you'll need; mine has no leak).
Mr. Gasket 5846 (FelPro is also good)
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_746668_-1_10199
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
2nd Amendment: America's original homeland security act!
wanabe
Re: olds 455
« Reply #7 on: August 03, 2007, 01:55:07 PM »
Rod covered this very well (from everything I've read); if using for cruising, 455 Olds will be no problem; if want to run excessive RPMs for extended period and hit 70+mph, you may hear a pop; if motor is out, you should put in the 10quart oil pan (at least 7; don't run with the stock pan); as Rod said, the oil doesn't return to the pan very quickly when running high RPM for a long time.
The 455 has good torque and should quickly pull a skiier out of the water and run them 35-40 as long as you want.
Also, I'm finding parts without much problem; they may not be in stock so you have to wait for shipping.
« Last Edit: August 03, 2007, 01:57:53 PM by wanabe »
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
wanabe
Re: olds 455
« Reply #8 on: August 03, 2007, 02:00:39 PM »
Kinda on the same subject; I do need an oil pressure sending unit (sender) for my 455; I picked one up yesterday but haven't installed; I started reading and get a lot of different opinions regarding psi/ohms/etc must match the gauge in order to get accurate reading.
Any thoughts on this?
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
hotrod56cars
Re: olds 455
« Reply #9 on: August 03, 2007, 03:41:54 PM »
Some oil sending units are for idiot lights, got to make sure the one you have/get is for a gauge. It is true that it has to be the right sender for the gauge. If you have the wrong sender no damage will be done, it will just read wrong.
I've swapped out a lot of gauges and/or senders and as of yet I haven't had any problems. It may just be my luck but I seriously doubt it's my luck...
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
Quote
GAWnCA
Re: olds 455
« Reply #10 on: August 03, 2007, 03:52:28 PM »
So, if I am reading this right and I don't plan on racing but maybe an occasional skier, the Olds is just fine for having fun in.  I'm one of those old farts that want to look like I'm a kid but not as bold as I once was.
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
~Greg
CHROMEY
Re: olds 455
« Reply #11 on: August 03, 2007, 04:53:17 PM »
my olds in my miniday runs hard, i only had one problem when the boat came out of the water and i broke the crank, i guess it spun a little high!!!, i have a 40ovr 455 as big of a cam i could fit in w/ the stock valvetrain ,performer manifold 750 carb, and "k" heads and it gets my miniday out of the water just fine....ps( its faster than my ford)shhhhhhhhhh...
  • Boat #1: 78 Omega California openbow miniday 22ft.-broken
  • Boat #2: 2004 Chevy Avalanche Crewcab
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
**livin la vida loca in las vegas......
**now open chromeys concepts photography, ALL PHOTO JOBS OPEN-WILL TRAVEL**
flytime
Re: olds 455
« Reply #12 on: August 03, 2007, 06:21:55 PM »
Wanabe could also use a rocker arm pivot for early 70's 455. Having trouble finding one. Someone out there must have one laying around. If so please contact.
Bob
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
the jet boat never did this to you bob ::)
Can I get next in line behind The Beav
wanabe
Re: olds 455
« Reply #13 on: August 04, 2007, 07:02:43 AM »
Bob
Flytime is jacking this guy's thread for things I need; go figure   ;D
OK, I started it.  >:D
Anyway, here's a pic of the rocker arm pivot (you can't see it but it's broke on the right side); I'm running with it broke since they are torqued down, it don't move man.
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
wanabe
Re: olds 455
« Reply #14 on: August 04, 2007, 07:04:08 AM »
That's the way I have it figured; should have no problem; I'll have to run mine a lot more before I can speak from experience.
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
hotrod56cars
Re: olds 455
« Reply #15 on: August 04, 2007, 10:13:38 AM »
Bob
Uhmmm... what's this?
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
Quote
wanabe
Re: olds 455
« Reply #16 on: August 05, 2007, 08:00:53 AM »
(Attachment Link)
I could put that to good use.
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
thecraz
Re: olds 455
« Reply #17 on: August 05, 2007, 08:28:37 AM »
call mondello 1-805-237-8808
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
If You Can't fuk It Or Eat It Piss On It
wanabe
Re: olds 455
« Reply #18 on: August 05, 2007, 08:41:02 AM »
I'll do that.
The only thing I found on their website was way small (http://www.mondellotwister.com/ARA-XXX.gif) and I only need the rocker arm pivot; flytime actually ordered that part # for me from our local source ($4) but when I picked it up I saw it was wrong; Rod's pic is the correct one.
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
hotrod56cars
Re: olds 455
« Reply #19 on: August 05, 2007, 09:14:32 AM »
... Rod's pic is the correct one.
 ;D You know the drill wanabe   ;)
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
Quote
wanabe
Re: olds 455
« Reply #20 on: August 05, 2007, 09:35:47 AM »
Rod, I can't get on the water today but I read you're planning on ElCap so get off the computer and go get the boat wet  ;D
I'm logging into PP now; right after passing on some karma; you're  8)
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
thecraz
Re: olds 455
« Reply #21 on: August 05, 2007, 11:12:18 AM »
you need to call mondello he has a lot of stock parts
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
Warlock
Re: olds 455
« Reply #22 on: August 05, 2007, 04:48:10 PM »
See Brad!!! Now everyone is jumpin' on the Olds bandwagon... ;) ;D
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
wanabe
Re: olds 455
« Reply #23 on: August 06, 2007, 06:09:26 PM »
Rod's sending me that one he has
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
hotrod56cars
Re: olds 455
« Reply #24 on: August 06, 2007, 10:22:34 PM »
It was sent this morning USPS Priority Mail.  ;D
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
Quote
