jet boat performance
Re: Questions:
« Reply #25 on: November 12, 2007, 09:08:54 AM »
IMO RE headers ,rechroming vs replaceing is almost not cost effective .time you strip bead blast treat and rechrome or recoat you have some "bank" in the project. Re preserving them, mist some wd on them and wipe down after use this is about the best you can do . RE The jet out of water, "in a perfect world" the impeller shaft is suspended for and aft between rear bearing and front bushing and thus so is the impeller (has clearance between the blades and pump body), so theoretically there is no contact between impeller and "wear surface", in or out of the water. All bets are off however if bearings and/or bushings are worn. Especially on Panther the Stnls Impeller will carve into the housing like a "boring tool". Sso key here is "is your pump tight in the first place" ? Tom ;D
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
Hava Al
Re: Questions:
« Reply #26 on: November 12, 2007, 09:12:33 AM »
 Tom.....The pump was rebuilt from Panther and only has about 6 hours on it....
  • Like
    Dislike
    Love
    HaHa
    Angry
    Surprise
    Sad
    Party
You know, a dick in the butt will fix that and you are coming down this weekend right
-beerjet-
